Cable/connection questions
I'm trying to use some stuff from work, instead of buying what I don't have to. Could use some RG-214, if not, what cable is normally provided? Also, what connectors are used to the CB and on the typical (firestik) antenna? I may be able to find some connectors and just solder it myself..
CBs have a UHF or PL-259 connector on the rear. At the antenna it depends on the mount you have. Some mounts have a PL-259 connector that connects to the bottom. Others, including FireStik, are just a 3/8" 24 thread stud. In that configuration the stud is isolated from the mount and a large ring terminal connects the cable to the base of the antenna.
RG-214 is 50 ohm so it is usable. CB cables that I have seen are RG-58. The RG-214 is double shielded so it will be a little stiffer. It won't be harder to run but the hinge pivot at the tailgate may cause it to kink or warp internally over time.
