CB Antennae Mount.... $36 for Everything...
The recommended length for coax is 18 feet. If you cannot use 18 feet, you can use a minimum of 9 feet with increments of 3 feet (example: 9, 12, 15, 18, 21, 24, 27). Be careful of what you do with your excess cable. If you need to wrap it, let it hang loose and carefully wrap it in a 12 to 16 inch circle (elbow to hand roll), wire tire it in the center, and put it out of sight under your seat or dash. Failure to do so could result in a RF choke.
The key here is "RESONANT ANTENNA", when we have a resonant tuned antenna (50 ohms impedance) and we use a matching 50 ohm coaxial cable and feed that into a matching 50 ohm radio, the laws of "Conjugate" are in effect and it wouldn't matter where you tested the SWR along the line, nor would it depend how many feet involved, there would still be a good SWR match with only slight variations due to natures pool of imperfections. The coax length should be just long enough to reach the rig.
For most cases when using a single antenna system with a 50 ohm coax feed ANY coaxial length will work providing the antenna is tuned properly at the feed-point of the antenna (where the coax attaches).
Grounding this mount makes little difference to the performance of the antenna. If the stick was being mounted to the center of a large flat metal surface (such as a roof or trunk lid) then a low resistance connection between the mount and the surface would matter. Why? This antenna is end fed which means that there is one lobe of radiated energy above the mount and (unfortunately) a matching lobe of rediated energy BELOW the feed point. A ground plane forces the energy in the lower lobe into the upper lobe and dramatically improves performance. Regretfully, there is no suitable metal surface on the JK that would provide an adequate ground plane. So the quality of the ground of the rear door only matters in that if it were poorly grounded it could be the source of noise in the receiver.
A better antenna for a mount like this is actually a vertical center fed dipole. It looks a bit like the firestick in that it has a fiberglass lower section with a radiator (wire) wrapped around it. The difference is that a coax cable runs from the base to the top end of the fiberglass tube where it is connected to the top whip and to the bottom radiator. This type of antenna requires no ground plane to perform well. Regretfully it would be very large for use on the 11 meter band.
I sure this will bring a howl of protests from many corners. But if in doubt go back to the books. The laws of physics are immutable.
