CB/FM radio antenna question
Old Nov 10, 2011 | 06:40 PM
G520's Avatar
From: Native to Los Angeles, but migrated to Denver.
Originally Posted by AK4Dave
Right, if you never need the stereo antenna, then you could replace it with a CB antenna. It would just be a matter of the right antenna mount and coax connectors to the CB.
That would be sweet!
Old Nov 16, 2011 | 07:13 AM
nate_every's Avatar
Default coax cable routing
When you are running the cable from the antenna to the reciever, is it typical to run it under the carpet or has anyone run the cable through the padding on the roll bars? Just curious, trying to plan this out before I get it so the install goes quicker. thanks for the insight
Old Nov 16, 2011 | 05:50 PM
Doc Holliday's Avatar
Originally Posted by Battlefrog
I did the license plate mount and so far so good...
where did you get the license plate mount from? just started looking into my cb stuff and like the clean look you got with that mount
thanks
Old Nov 16, 2011 | 06:08 PM
AK4Dave's Avatar
I wouldn't say it's typical. It's what ever you prefer, and what works for you. Nothing wrong with running it on the roll bar if that's the way you want to do it.
