Clean cb install, perfect fit
Old Feb 7, 2011 | 08:29 PM
RescueGreen#3's Avatar
Originally Posted by SLIM_SNOOPY
Nice Install:
A small tip, If you start to expierence engine / ignition noise or interference with your Jeeps electronics, it is due to pulling power from the power outlet. CB's radios should be wired directly to the battery to avoid the above issues. Even though the power outlet is suppose to be a 12 volt accessory tap, the wiring still passes through the fuse box before going to the Jeep's Battery. Thus, giving more chances for noise and interference issues. Just trying to pass a helpful tip if you or any other member's expierence problems.
SLIM
Hey, thanks for the post^^^ I was about to wire it like the OP did. Now, I'll just route thru to the battery.
Thanks both of you for this thread
Old Feb 8, 2011 | 11:28 AM
erol1991's Avatar
used it for a week now. no problems with the radio
