Cobra 75 wiring question
Old Jan 22, 2008 | 05:12 PM
y2ksir's Avatar
Default Cobra 75 wiring question
I will be instaling my Cobra 75 this weekend, but have a quick question that I couldn't find an answer for.
I want to avoid wiring it directly to the battery incase the unit is left on (don't want to drain my battery). Is it possible to tap into one of the power outlets in the dash or will that fry something?
Old Jan 22, 2008 | 05:18 PM
poppakristof's Avatar
The left power outlet on the dash is only powered when the key is on.
The right one is powered constant.
Old Jan 22, 2008 | 05:40 PM
bertjnkns's Avatar
From: East Texas or Shreveport depending on the day
My sirius is tied directly into the left lighter receptacle, it's switched, comes off and on with the ignition. I spliced my cb the Cobra 75, right into the same wires coming from the sirius. I have had no issues so far.
If you left it on I wouldn't think it would draw enough to matter. What I want to do is come straight off the battery with a fuse block and mount it under the glove box and be able to tie into it with my cb and any other accessory. There are some good write ups on that here.
Old Jan 23, 2008 | 11:11 AM
scouter4life's Avatar
I have the Cobra 75 and find that most of the time I have it unplugged, so I don't need to worry about it draining the battery. Unless you plan on using it most of the time, I'd keep it out of sight to prevent any sticky fingers from grabbing it. Like has been said, connecting directly to the battery is best.
Old Jan 23, 2008 | 12:04 PM
2K1TJ's Avatar
Originally Posted by N2rock
I was advised by a friend of mine that is a HUGE CB nut, that CB's should be wired direct to the battery in order to have proper ground and prevent RF interference.
What he said.
Old Jan 23, 2008 | 07:31 PM
y2ksir's Avatar
Thanks for the advice and tips everyone. I will connect it directly to the battery. I love this forum.
Old Jan 24, 2008 | 02:24 AM
wayland1985's Avatar
and it loves you...
