Dead Center Antenna Mount
Old Oct 21, 2009 | 01:26 AM
renegadelt1's Avatar
Originally Posted by Flyguytki
Unbelievably after I removed the tuning screw in the top the CB is tuned Perfectly, we had a perfect match on channel 40!!
-david
Old Oct 21, 2009 | 02:21 AM
sin52's Avatar
I will admit it is not to great, however I only use it when on the trails so it does its job just fine. Any ideas on how to make it better tho??
Cool.
I also wanted a centered antenna, for cheap too.
Here's what I did:
https://www.jk-forum.com/forums/jk-cb-ham-radios-128/3rd-brake-light-antenna-install-96042/
Though you might be able to use this idea for grounding purposes. I've removed the tire carrier and antenna mount last week to check for corrosion and none is present. No water has worked it's way in, anywhere.
PM me if you got questions on anything.
