Experience/Pictures of Breedlove Antenna Mounts?
Old May 26, 2012 | 08:14 AM
  #21
arjeeper's Avatar
Yeah, every mobile install is a balance of various compromises. I chose the AH-4/non-resonant whip option because the only other real multi-band HF option--a screwdriver antenna, would probably be ripped off the Jeep by the first branch that came by!
I'll also be brute-force chocking the coax off with quite a few large clip-on mix 31 ferrites.
Old May 26, 2012 | 08:47 AM
  #22
gs2offroad's Avatar
Yes, mobile HF is all about compromises. Fortunately when propagation is good, most anything will work.
I run a whip/tuner combo because I travel a lot of washboard/high speed/desert terrain. A screwdriver can't take the abuse as well.
Name:	Another antenna.jpg
ID:	321782Click image for larger version
Name:	Crap antenna.jpg
ID:	321783Click image for larger version
Name:	Tarheel broken again.jpg
Old May 26, 2012 | 09:30 AM
  #23
arjeeper's Avatar
Ouch! Lost that one!
I wish I could mount my 706 body in a similar location, but I rarely have the top on in the summer and it would just be too exposed. Not exactly sure where I'll put it yet.
Old May 27, 2012 | 04:15 AM
  #24
goldtr8's Avatar
my 7000 is under the passanger seat then the remote head on the counsel.
Dont put it under the driver seat there is more heat there from exhaust and stuff gets hot after long drives.
Old May 27, 2012 | 04:17 AM
  #25
goldtr8's Avatar
Originally Posted by gs2offroad
It's much worse than you think, the AH-4 is the base of the antenna and should really be mounted outside the vehicle.
But for what I use it for, the setup is fine. Kind of fun to watch the computer go batty when TXing on 20.
73 Mitch K7MSC
You really want to get that fixed by proper choking, computers can be a wee bit expensive, plus its no fun when faults get held or cause driveability problems when you need power.
Old May 27, 2012 | 04:20 AM
  #26
goldtr8's Avatar
Attachment 321782Attachment 321783Attachment 321784
Glad I have a scorpion, mcuh better built than the tarheel you have shown in the picture. What did the tarheel guys say after the failure? Or should I not ask this question.
