Grounding
Old May 4, 2009 | 06:49 PM
JKScott's Avatar
Question Grounding
I just installed a Cobra 19lite (I don't know the exact name) CB Radio and mounted a 24" coil antenna on the spare tire bracket. The CB itself is grounded and I'm supposed to ground the antenna also. Should I ground the antenna or would that create 2 grounds or a ground loop?
Old May 4, 2009 | 08:33 PM
wal0vitch's Avatar
You need to ground the antenna....
