grounding advice--
Dont laugh. On the right frequency the muffler and tailpipe can act like another antenna. I have 2 ground straps on mine back to the frame.
That's true....so can ANY particular wire on your rig that happens to be just the right length. Fuel pump noise however is usually real hard to get rid of. You may want to try a ferrite choke for this.
I just installed my Antenna using a Teraflex mount, didnt need a ground, I measured it with a multimeter and had a 1ohm ground from the mount to the frame, SWR was .5:1 on 1 and 1.75:1 on 40.
So I am not even sure a ground is needed on these tail gates.
