HELP! 08 JK computer goes into fibrilation when push cb talk button
I had a similar problem last week when wheeling, everything worked fine on the radio, but while wheeling I hit the transmit button on my cobra 29 and the dash lights all came on and the nav radio reset, as if the power turned off and back on, but the engine didn't cut out. I have it wired to a aux. fuse box and just recently installed a new nav radio, wonder if the ground going to the radio somehow was damaged during the radio install and I need to redo the ground connection?? Kinda scary, thought the electrical was going to cut out on me. I had to just listen and not transmit for the rest of the weekend, seemed to come and go, tried to transmit the next day and it worked, then later on the trail it did the same thing.
I have a firestick grounded to the rear bumper and the radio is grounded to the dash frame behind the glove box. Could having two grounding points cause some sort of ground loop issue? I got nothin...
Oh yes.........probably more than when it's running....like sitting on top of a mountain or at camp....etc...
