Here is where you should mount your CB and HAM antennas on your Jeep
#292
I've never tested the range I get on my CB (I have my ham for range). With my shorty ham antenna on my driver side mount (~18"), my Kenwood can hit a local repeater from 50+ miles away. With my 2' Wilson CB antenna on the passenger side mount, people in my trailer group sound like they're in the jeep with me. A front mounted antenna might give me a little more range on my CB, but I really don't need more range for what I use my CB for. Plus, I feel that having my antennas centered behind the cab offer a wee bit more protection for bushes when I'm getting some desert pinstriping (and I'm not a big fan of the whole unicorn look).
#293
Hot sure how efficient it really is or what kind of range it gets, as I haven't really tested it for that, but my 3' Firestik CB antenna is mounted on a tab that's welded to the rear corner of my PSC Crusher steel flares. I've honeslty only used the radio once or twice on the trails since I installed the corners and it's done great for that purpose. But being as it has constnat power and drains my battery, I currently have my radio disconnected until I get off my lazy A and wire it up to a master switch I have beside the steering column. I'll try to get a picture this afternoon when I get home if I remember, but so far, this mounting location seems to work pretty well.
#294
#295
My install
After having numerous issues with SWR while trying to mount my Diamond HV7A quad band antenna behind my spare tire for clearance, I read this thread and came up with a homemade mount. The cowl location is not sturdy enough to hold the massive weight and windload of the HV7A, so the windshield bracket is the next best location. I used some 1/8" thick by 1 1/2" wide weld able steel stock from True Value and made a bracket. It holds solid and only cost me $10 with plenty left over for other projects. I was initially avoiding this location since I park in a garage, but the driver side mount let's me reach the fold over hinge from the driver seat. It's worth the inconvenience for the increase in performance. Now my SWR is 1.2:1 over most of the 2M band and 1.1:1 on 70CM. I haven't checked 6M yet due to the lack of an appropriate meter and I'm only a Technician so 10M doesn't matter right now. The cable run is about 5' and it goes through the door, which some may dispute, but there is the rubber gasket for the inside of the window bracket that allows the coax in the vehicle with no door pinching. I'm currently running a TYT-TH9800 with the base of the radio under the driver seat, and an external speaker mounted right to the sound bar. The face of the radio is held to the windshield with a RAM suction cup mount that I had from an old GPS. Overall it seems to work very well. Power and ground are to the battery through the firewall using a 3/4" hole I drilled behind the glove box. 3/4" grommet protects the wires. I used a new hole because I also have multiple emergency lights and siren speaker wires run as well. I have attached pictures of the mount. You can see my little 1/4 wave in the pic as well for my EMS radio and they are on same side to avoid all of the issues with the AM/FM stereo antenna. They are far enough apart where there is no issue. The only thing left for me to do is to run a good ground strap to the radio base for better operation on 6M, and I have to paint the bracket.
I hope someone finds this info useful and maybe it can save you time playing with different options like I had to.
73 KD2HWO
73 KD2HWO
*****Updated November 11, 2014 *****
Jeep Antenna Placement Recommendations. CB ~27 Mhz, HAM 140-148 440-450 Mhz and Commercial 150-170 450-470 and 800 MHz Frequencies. For low 3 to 7 Mhz HAM antennas I’m not covering that here as those are special antennas and if you have a license for those frequencies then you already know what your doing.
I have been looking around the forum at the descriptions for antenna placements and there is some good advice out there, but not all in one place so I have decided to make an easy English description for those not so tech savvy. Please keep in mind that this post is to describe the best balance of function and looks. Granted putting an antenna in the middle of the hood is a great transmit spot but it’s in your field of view and makes the Jeep look like a unicorn.
Background: I am a commercial two-way radio tech with Ham and marine licenses. I have been doing installs for about 18 years. Like police cars, ambulances utility trucks and the like.
Guidelines to follow and these are relative to your situation. For example: if you park your Jeep in the garage you can’t put your antennas on the roof rack so the cowl is you next best thing.
Guidelines:
1 The longer the better. (Relative to your situation if you have 5000 foot peaks that have repeaters a small antenna like mine will work fine, but if you need to talk on a simplex/direct frequency the longer the better.)
2 The largest horizontal ground plane the better. A horizontal ground plane is exactly that a flat piece of metal or metal spikes going off in 4 directions from the base of an antenna. (See exception to this guideline later in this post)
3 The farther away from vertical flat metal the better.
4 Keep the antennas separated a foot or even more is better. Keep VHF 150 Mhz away from the stereo antenna. If you using a scanner that does not transmit then that’s ok next to the stereo antenna.
5 Avoid Bumper and license plate mounts if possible.
6 DO NOT PUT YOUR ANTENNA BETWEEN THE TAIL GATE AND THE SPARE TIRE
7 DO NOT PUT YOUR ANTENNA BETWEEN THE TAIL GATE AND THE SPARE TIRE
8 Just to make sure you are reading this correctly DO NOT PUT YOUR ANTENNA BETWEEN THE TAIL GATE AND THE SPARE TIRE. Read below for a more detailed explanation on this.
I will put the easy answers here at the top with more detailed explanation at the bottom for those interested. Listed here are the best to worst places to place antennas at the bottom I will also talk about other types of antennas that I don’t have images of.
1st On top of the center of a roof. If you never plan on taking off the hard top off then the things you can do are place a large piece of metal under the roof, attach the antenna to a roof rack or get a no-ground plane antenna (guideline # 2 exemption).
2nd On the cowl. Must effective place after the roof and it allows you to have longer antennas and still make it the garage. Also is good for those that don’t want to drill holes in their body. I have 5000 foot mountains so I don’t need a long antenna.
Seen here is my small dual-band antenna for HAM use.
Note: if you need to place more antennas on the cowl try to avoid VHF 150Mhz near the stereo antenna as transmitting near that antenna will cause noise on your car radio.
3d on the corner of the Jeep. This is preferred over the bumper because it gets the antenna up above the body metal line. You will see the light bar from Olympic in this shot and they advertise it as a place to put antennas. This may be ok as it’s away from the body of the Jeep. Seen here is my commercial 800 MHz antenna looks like the one in front but its coil is in a different place.
4th Bumper: You see an Olympic bumper here with a hole for CB antenna This is OK but not Ideal as the base is still below wall of steel on the body. A license plate mount would have the same problem.
5th Between the tailgate and the Spare tire. As I said before DO NOT DO THIS UNLESS ABSOLUTLY NESSARY. AND DEFINITELY NOT FOR HAM OR COMERCIAL FREQS. Besides being the most inefficient place for and antenna one can’t open the window and close the tailgate.
More detailed stuff.
The Jeep Wrangler presents us with a problem it’s a convertible with no metal roof. Two-way radio antennas weather they be CB, HAM or Commercial need to breathe. I.E. it needs to be exposed to air with as little horizontal metal next to them as possible. It also needs a ground plane under it. Ideally the ground plane should be a diameter equal to ½ of the wavelength of the frequency. So a 150 Mhz antenna would have a diameter of about 38 Inches CB would be about 6 yards NOT TO BE FOUND ON A JEEP.
The nice engineers that make antennas use coils and such to compensate for this. Here is where our unique problem lies these coils need to be exposed to the air and not near horizontal metal as much as possible. Nearly all ham and commercial antennas have coils and they are at the bottom of the antennas. So placing them on the bumper right next to the body will cause the radiation to be reflected back in to the radio which over time will damage the power amplifier in the radio. The cowl and the higher rear corner placement is desired because the roof is made of fiber glass and the radiation will just pass through it. Yes there are pillars and roll bars but the radiation will bend around them verses being reflected back.
The tailgate and spare tire situation yes, I know all our favorite web venders sell tailgate antenna brackets but they should only be used as a last resort. And again I know in caravan style on the trail they work fine and Jeepers have been mounting them there for years but …
This is why they’re bad. Remember the base of the antenna must be exposed as well as the whip. Think of a nuclear bomb going off the gamma rays can’t pass through 1 inch of lead or 10 feet of concrete and in our case of two-way radio signals the tailgate and spare tire are acting like a sandwich keeping our radiation inside and not allowing it to escape. I started here just because I thought it was cool looking. However mounting the antenna here proved to be fatal. Basically I had two pieces of large solid metal surrounding my antenna base causing massive reflected power going back into my radio and not radiating out. I used a watt meter to measure what was happening. Some of you out there may have access to something called an SWR meter and that’s fine if you know how to use it, it will tell you the same things. I use watt meters because I need to know how much power is coming out of my radios for commercial purposes to satisfy FCC rules. Ideally if you have a 30 watt VHF radio you want 30 watts transmitted out with as little reflected back as possible. 30 watts with say less than 2 reflected is great. I had 25 watts with 20 reflected. The more reflected back will also adversely effect the power out which is why I had the lower number on output. After tuning my antenna to 30 watts with 2 reflected the antenna went from about 50 inches to about 30 inches making it nice long high gain antenna useless. And of course one can’t open the back window and close the tailgate without removing the antenna thus making that random trip to the hardware store for 2x4’s a bit of a problem without a roof rack.
For those of you who mount your antenna base above the spare tire with an extension there is still the problem of a ground plane unless you use say the Olympic light bar or make a bar of some sort you end up with the same problem. There is an exception to this rule as mentioned in guideline # 2 above and that is a no-ground plan antenna they do exist for CB, HAM operations and radio towers. Of course you could use one on the fiberglass Jeep roof too but then you can’t take the top off or get into the garage. Just remember keep the base as well as the whip away from vertical flat metal. Like the tailgate spare tire and body. Pillars and roll bars are ok but try to keep the antenna as far away from them as possible too.
Other antennas that you may have seen or many want to use:
1 On-glass antennas, I have used them but they are not great. They don’t have a good ground plane and lots of reflected power. I would avoid if possible.
2 I would also avoid dual-purpose antennas like ones that use the car stereo antenna as a VHF antenna with a splitter box one to your stereo and the other to the Two-Way. Not to be confused with dual-band antennas that’s different and used for HAM Frequencies.
3 Side ball mount antennas, used for CB and military frequencies. As long as they are mounted to the highest point on the body the better. You may have seen these long whips that bend down to the front of the Jeeps. This served two purposes that I know of one was so the whips did not hit the trees in the jungles and the other was to make the radio talk shorter distances. See at 100 Mhz the radio waves pass through the atmosphere below that they bounce back to earth commonly known as skip. The whip standing vertical could skip from New Mexico to Louisiana but bent over It could talk from one side of New Mexico to the other. This all of course depends on frequency, power time of day and sun spots.
4 Magnetic antennas, these are good for the temporary weekend trip as long as they attached to a good solid piece of metal. I would not recommend them for permanent mount as usually the coax is put through a window or doorframe and will eventually get damaged.
Here is an image of different radiation patterns. I don’t have an image for what it would look like for the tailgate and spare tire but basically the signal isn’t going very far. The center image shows the most ideal relatively round even pattern. The corner mounted antenna show what happens when the antenna only has a ground plane on two sides and not 360 degrees.
*** MORE TECHNICAL UPDATE ***
I conducted an experiment using a Commercial grade CB antenna Made by Tram with an NMO mount. I tested it on the Cowl, Rear Corner, Rear bumper and the rear light bracket with an SWR Meter. In the pictures you will see a bulkhead mount that I used. I used one on the light bar with and with out extra radials to see if it would improve the readings. I don’t have any “fire stick” style antennas and those may get a lower SWR reading however I believe my experiment shows the basic difference in performance one can achieve on the different locations of the Jeep.
Readings
Cowl SWR 1.2 result Great
Rear Corner SWR 1.5 result Good
Light bar with and without the extra radials SWR ~2.0 result Not the best
Bumper SWR 3+ Result Very Bad.
NMO Bulkhead mount
NMO Bulkhead mount with radials
NMO Bulkhead mount on bumper
*** MORE TECHNICAL UPDATE *** 11-12-14
Recently I cracked my intake manifold changing a censor. I had my mechanic add some headers and new spark plugs at the same time he replaced the manifold. Needless to say by doing so we disturbed the electrical system of the Jeep thus causing RF (Radio Frequency Radiation) leakage. It sounded like bacon frying on my VHF and UHF analog ham channels all across the spectrum, both receiving and transmitting.
To solve this problem I ended up swapping my dual band VHF/UHF antenna from the Cowl to the back and put my 800 MHz antenna on the Cowl. This got the antenna enough away to solve this problem.
But a new problem was also discovered. My 800 is a commercial digital radio and although the digital signal did not pick up the “bacon frying noise” it made the radio less sensitive.
To solve this problem I tried to put a brand new coax with new antenna and connector, SWR checked great. But that did not work so I ended up relocating my 800 antenna to the rear light bar bulkhead mount as seen in the above pictures. Once there my receive signal strength came back.
Guidelines:
Readings
NMO Bulkhead mount
#296
73 KD2HWO
Attachment 633448Attachment 633449
73 KD2HWO
#297
Here is my setup from when I was in a Unlimited a few years ago maybe these will help some folks..
Glass mount for 2m, my goal was simply to hit the local repeaters if a SOS situation occurred in the woods around here....Cell has a few drop outs in signal where we wheel, never had any problems working the repeaters..
Yaesu 2m on a cup holder mount..
Ran the mounting bracket for the radio under the front seat.....Before someone posts it, heat was never an issue, nor did I ever submerge my Jeep in water deep enough to fill the tub..
RCI 2970 mounted center dash for 10/11m..
and lastly a 102 whip mounted on the dreaded tire carrier mount....I had a Firestick to swap out for running in the woods so the whip didn't impale someone by accident..
good enough for who its for..
For what I was doing with MY setup everything worked just fine........YMMV
#298
*****Updated January 22, 2016 *****
Background: I am a commercial two-way radio tech with Ham and marine licenses. I have been doing installs for about 21 years. Like police cars, ambulances utility trucks and the like.
Guidelines:
2nd On the cowl. Must effective place after the roof and it allows you to have longer antennas and still make it in the garage. Also is good for those that don’t want to drill holes in their body. I have 5000 foot mountains so I don’t need a long antenna.
3d on the corner of the Jeep. This is preferred over the bumper because it gets the antenna up above the body metal line. You will see the light bar from Olympic in this shot and they advertise it as a place to put antennas. This may be okay as it’s away from the body of the Jeep. Seen here is my commercial 800 MHz antenna looks like the one in front but its coil is in a different place.
Readings
NMO Bulkhead mount
Guidelines:
Readings
NMO Bulkhead mount
ktm2ride (03-21-2018)
#299
I have my FM/AM radio rigged to a Firestik antenna and ran it to the back. It's currently right next to the taillight and I get signal interference from the wires (that it runs it's route through towards the rear). Is there anyway to avoid the interference? I'm not sure how else to route the cables from the radio to the rear aside from the same path as the rear functions (taillight wires, reverse, trunk unlock, speakers etc), which is right along the the passenger side (plastic lining) on the floor. Let me know if that was confusing because I think I worded it poorly
#300
First off - thank you for a great thread! I'm now ready to move on to my next mod - which will be a cobra 75 cb..
After reading thru all this - it seems the best location for an antenna mount on the JK is the front driver fender and the worst location is pretty much anywhere on the back gate. So - of course I would like to mount the antenna on the back gate! :-)
This being said - would a AZ Rocky Road mount be a better choice (because it would have the base of the antenna above the tailgate) than any of the mounts that position the antenna lower on the tailgate (TF/RR/Cooltech/ etc) ? I am running a swing away tire carrier and 35" tires - so I'm concerned that my SWR with the antenna sandwiched between the 2 will not be ideal...
My JKU is lifted 3.5" but am still leaning towards a 4' FS. I'm sure I will be removing it for all parking structures and garages..
This placement / mount is my last issue before I can make this mod happen. Very much appreciate the help!
Alex
Alex
