i hear nobody!
ok thank you dave and mark for postin that great info. i read it all, and also read the instructions which i prob should have done before. the power knob adjusts the output power, and the rf gain adjusts the loudness. so i put the nb switch in nb/anl which is a noise blocker for ign noise.. stuff like that. i re-tuned my antenna, and it works amazing now!! i have the squelch all the way counter, and with the rf gain knob low i can hear ppl loudly, but the fuzz is very faint. i guess tha rf gain knob controls the fuzz.. so to speak..
on my swr test now the meter barely even moves 1 to 40!
so the problem... i bought a great advanced radio and didnt read the manual and that was the problem. everything i installed was correct.
also snugged antenna down with pliers too.. a lil tighter than hand.
lesson learned!!
lesson learned!!
lesson learned!!
lesson learned!!
Good deal.......the RF gain is your ears/receiver. Meaning you can turn it down when there is say......a trucker running big power right on top of you as to not overload the front end of your radio. But for the most part leave the RF gain turned all the way up as to hear even the weakest signals. Never know when you might hear a very weak "mayday-mayday". Use your squelch only if you get tired of hearing air noise, and turn it up only to the point of blocking it out. That way any decent signals should break the squelch allowing you to hear them.
Many times, I have been told "You sound like a local" and he will give me an S9 plus 30 over signal report. But he may be in Japan and I am in Alaska. Then again I may talk to a guy somewhere in ALaska, and he may only give me an S3 report.....and visa versa.
An "S" meter reading only has to do with how strong a signal your radio receiver is picking up, it has nothing to do with the distance between you and the station that is transmitting. Yes, a station may be so far away that you can barely hear them and your radio is only showing 1 S unit. But it's not always the case.
that makes perfect sense dave!! u prob know alot more than i about cb, so i trust your statments, plus it just makes sense.
i am having fun with the radio now.. picked up someone 9 miles away yesterday so i'd say its workin, and he heard me loud and clear. i guess as more time goes on i will perfect my cb skills and no one can take knoledge from u!
thanks again dave!
thanks again dave!
thanks again dave!
thanks again dave!
Have Fun...!!!...
