iCOM 2820H D-STAR install
Old Jul 16, 2010 | 05:54 AM
joelb's Avatar
Originally Posted by Kev69
I just wanted to say that I really like your setup and I think that's what I'm going to need to get is a radio of this breed.
where you put the wire thru with the phone plug type did you just cut the plug off and re-do or did ya just drill enough to put it thru?
did you have to put a ground wire on the antenna also?
thanks
ve1kev
Thanks!
We routed the head unit cable down along the plastic covering going from the center console to the shifter then came up behind it under the row of switches that has the ESP switch on it. We just got an extra long cable and it stays in the Jeep when I remove the radio. I have the regular cable in my go box. Everything was professionally done by a local company I use who install police radio and lighting systems.
I did not have to use a ground wire on the antenna. I used a Maldol eXceed Series eX-107B NMO antenna with a Comet RS-730 mount. The mount fit securely under the lip of the hard top and we ran the slim part of the cable underneath the top and sealed it very well then ran the rest of the antenna cable down the same path the other cables take to the front of the Jeep (along the drivers side).
I use Anderson Power Poles to connect the radio to the power amp (and to the amp in my go box). To remove the radio from the Jeep, I unscrew the thumb screws that hold the base unit into its mount, unplug speaker/head unit/mic/power wires from the base unit freeing it then unplug the head unit and mic. This all takes less than 5 minutes and another 5 minutes to plug everything into my go box with Alinco Power Supply DM-330MVT, APC Back-UPS 1500L uninterruptable power supply (with extra batteries), external Diamond SG700 Super Gainer antenna, and Heil Sound "The Traveler" Dual Headset with Boom Mic and I'm ready to communicate for many hours. Adding a laptop with D-RATS and I can do digital messaging, file transfer, and email over the D-STAR system we have statewide in Georgia. Rock and roll baby!
Joel
Old Jul 16, 2010 | 05:59 AM
joelb's Avatar
Originally Posted by goldtr8
fyi I mounted my IC7000 under the passenger seat due to heat concerns the exhaust runs under the driver side and it gets hot right there so you might want to chrck this on your jeep
I don't have it mounted directly on the carpet under the driver's seat. There is a good 1 inch space there for airflow. And, the IC2820 has an automatic fan system that only comes on when needed (apparently there's a temp sensor in the base unit). I only hear that sucker come on after I've been transmitting for a while (10+ minutes) so I know it's not overheating. Plus, with Georgia summers consistently hitting 97+ degrees, I think it would get a lot hotter from that than from transmitting and I still don't hear it come on as often as I thought it would in the Jeep.
Joel
Old Jul 16, 2010 | 07:30 AM
joelb's Avatar
Originally Posted by Desert Fox
W4JOL,
I understand why you didn't install the mounting bracket under the driver's seat - too much heat
from the catalytic converter. BUT, under the passenger's seat is the gas tank. Did you drill holes
through the floor board? How did you protect the plastic gas tank?
W6PBR
I DID install the radio under the driver's seat. Well, actually "I" didn't... my installer did and they sealed everything after using metal screws to get through the floor.
Joel
Old Jul 18, 2010 | 12:49 PM
goldtr8's Avatar
W4JOL,
W6PBR
I built a bracket that allowed the mounting on the seat mounts. This way I have airflow above and below the radio.
Old Dec 5, 2010 | 05:29 AM
Hulk's Avatar
With the 2820 can you run the power straight to your battery? Or will it need a little more juice? Nice set up btw!
