(Post 1607435)
In the Jeep, on CB you should be able to talk a mile or two reliably on the Interstate. On the trail, you should be able to talk to anyone you're running with unless you put some obstacle between the two of you (same problem with 2-meters, BTW). It sounds like you're getting more the lackluster performance typical of handheld FRS radios. I'd say check out your antenna system, and if that checks out, consider moving it. The one advantage of CB over ham is that most Jeepers will have one if they're heading out on trails.
I would say the the ONLY advantage of CB over ham is that most Jeepers have it. Me, I'm sold on ham now. |
Originally Posted by JeeperDude
(Post 1607805)
... Me, I'm sold on ham now.
(Post 1606973)
There are a variety of factors in the range calculations, so I had to make some assumptions--path loss, antenna height, antenna gain, etc. You can't compare your eight mile experience with the numbers I used. Therefore, unless you ran actual range tests and have before and after data, all you may have proved is you increased your range for your particular circumstances from perhaps 7.2 to 8.3 miles. You really don't know (and neither do I, except to the extent that the range calculations reveal--and they are pretty accurate. I'm familiar with this because every military radio installation I helped engineer and purchase used these equations to determine expected radio range).
(Post 1607929)
Ham radio is great stuff. But, roughly how far are you getting with that CB? What was the terrain? Were your trail buddies also having similar difficulty with range? Something sounds amiss when you're talking a hundred feet of improvement. :thinking:
(Post 1607416)
You know, I had that in there, in fact. But, I went skulking about for an antenna lobe pattern chart to illustrate what I meant (didn't come up with one before I had an errand to run) and while visiting the Firestik website they say that they have experienced increased gain with antennas as close as four feet:
"32. Some people believe that co-phased antennas must be separated by a minimum of nine (9) feet. We have successfully used co-phase antenna systems with spacing as little as four (4) feet. Space alters the pattern and not always negatively. Each vehicle will be different." From http://www.firestik.com/Tech_Docs/63Things.htm So, while I'd always heard what you wrote, Dave, I decided to remove my words saying the same thing. I guess folks can try things out and see what happens. When it comes to RF, it's all FM (frelling magic--I've been watching four seasons of Farscape the past few weeks. LOL). P.S.: Here are some antenna lobe pattern charts to illustrate what I wrote about above. Not for you, Dave, for those who haven't seen one before ... http://www.vias.org/wirelessnetw/wndw_06_05_05.html You know for yourself that there are reasons yagi antenna elements, the driven, directors and reflectors, are spaced as they are. There are formulas that dictate this. This is no different. But I must say that there is one thing where most HAMs do agree, is that it all looks good on paper, but until you put it up and try it you'll never know. |
Wow I just learned more about radios in 3 minutes reading this thread than i did in my entire Ham Technician review class. lol, just kidding.
I have a uniden 520xl pro and a the Ultramount bracket connecting inside my license plate bracket. The only problem i ever run into is that people can usually hear me but I can't hear them (mostly if they are in the front or rear of the pack). This usually only happens when i run my 3ft firestik versus the 4ft Firefly which actually reaches above the hardtop. I bought these at the actual firestik shop in Phoenix and they said the 4ft one is better because it's coiled more towards the top of the antenna which will get the signal out above the jeep versus the 3ft firestik. I use the 3ft one in town so that i can pull into the garage without banging anything. Problem is I usually forget to swap it out with the 4ft one when hitting the trails. For most intents and purposes on the trail though, the cb setup i have works fine. It's not "tweaked" but I'm able to hear just about everyone and they can hear me. For talking the long distances I have the Ham radio but most jeepers here in Vegas don't have one. The group I used to run with in Phoenix almost all had Ham radios. It was awesome! We'd talk on Simplex after splitting up after a trail run and we'd just keep on talking for miles and miles almost until we were at home. Even on the trail in rough terrain these ham radios have incredible ranges versus the CB. |
Glad I didn't throw away my hooker amp
I picked up a cheap Uniden 520XL and a 3' Firestik II, with good line of sight I transmit and receive people 15-20 miles away clearly.
That's a little more than 2.5 miles?? |
I've been running peaked radios for years and I also run amps that will push 1500 watts ! But the first thing that needs to be altered is your charging system to run these amps! From voltage regulators and high output alternators to 2 or more high output batteries just to maintain peak power! It's a very complex thing to do! And can really mess with your electronics in a jeep! I would leave that to the suburbans and big rigs on the road! Lol
In my jeep I run a power adjusted cobra 29 that dead keys at 2 watts and swings to 28 watts perfect for talking up to 5+miles NO PROBLEM with no amp and a Wilson tunable fire stick whip! And I live in the northeast where buildings and trees and roads and all kinds of communication sources block signals! So out in the open my radio will talk for miles |
Gmrs
GMRS radios work fairly good too and solve the license issue of the Ham (as you license the radio essentially). Even a cheap camping store pair of these handhelds work great on the trail. Much better than some of the better CB setups I have had in fact. Plus for the cost, you can have 7 or 10 of them laying around and just pass them out to the other members on the trail ride with a fresh set of batteries. Also, you can invest in a surplus VHF mobile radio and have it programmed to LEGALLY use on GMRS and Ham frequencies. This is a great solution if you are so inclinded. The GMRS handheld idea works great too because if for some reason somebody has to get out of the rig and walk, you simply take the radio with you...also prevents theft and vandilism...
