Instaling the antenna stud in Teraflex mount
I just finish instaling the antenna and check with a meter and it didnot have any ground in the base. I took out some paint in one of the bolts and in the bottom of the mount where i instal the stud. Now i have a good ground.
The overdue update.... the high SWR readings have been corrected. In addition to all the adjustments previously mentioned, I finally discovered that my antenna mounting stud had a crack in it which may have caused an undiagnosable short.
After finding this I contacted Right Channel Radios who immediately responded by placing a replacement stud in the mail. It arrived today, I installed it and now my rig tunes in between 1.5 and 1.8.
Thanks for the help that so many of you offered, and the fantastic customer service from the vendor.
I was having terrible SWR's with the Teraflex mount. Finally I grounded both the antenae to the mount, and the mount to the tailgate using a star washer to cut through the powdercoat. SWR's went from >3 to about 1.1. It only took me three years to figure out.
