Its installed and it works and works kinda
Old Apr 11, 2010 | 09:51 AM
AK4Dave's Avatar
Originally Posted by goldtr8
I know I am ok with the 1.6:1 swr for the 10 & 20M. My problem is the 40m stick wont go below 3:1 and the 75m stick wont tune for the 80m. So in a few weeks I will be in Columbus Ohio again and I was thinking of getting a tuner from Universal Radio.
The more I have read and discussed with a tech at Icom the more I think its a good idea to have the tuner.
So a little bonding of the panels and hopefully that will get rid of a little of the noise in the system and then the tuner and I am good to go for awhile.
We need to set that SKED up.
Ok.......regardless if you put a tuner in line or not, if you don't get the 40 and 80m sticks "somewhat" resonant, you will still have very, VERY little power out on those bands. See all a tuner is doing it tricking the radio by showing a match. it doesn't change the properties of the antenna.
If it were me, and I had that bad of swr on those bands. First I would start by putting 3 or 4 more BRAIDED ground straps throughout the jk. At least 2 large ones from the tub to the frame....maybe one in front and one in back. Then maybe a smaller strap from the the doors to the tub. You can't have too many ground straps when trying to create a sufficient ground plane in a vehicle. ALL the metal on a vehicle needs to work as one.
Then if that didn't work I would remove the 40 and 80m sticks from the vehicle and MOUNT them to a pole driven in the ground with a few radials strung out. At least this way you should be able to see if, or if not, they even tune at all. If they tune up when they are attached to a pole in the ground, then you know there is nothing wrong with the antennas themselves, and you will need to do some extra work on the jeep. If they don't tune, and they should, you may want to think about taking the antennas back for new ones..... capishe...??? I have never actually owned any HAM Sticks as other than 10m I have never run HF in a vehicle. I've only "heard" first hand as to how well they play. Is there no tuning adjustments on them at all? I know they work on 40 as I've talked to a friend in Santa Barbara CA. from here in AK. He was sitting in his van in his driveway and he had a fantastic signal even with only 100w.
Oh and btw......here is a WEALTH of knowledge about mobile ops: http://www.k0bg.com/
