Mounting a CB in my Jeep.
How did you mount your CB radio? I bought a little cheap one that has a simple U bracket. However, not sure where to mount it.
I was thinking to purchase a shelf that rests on the dash above the radio and mounting it to that. I have to see if I can find the shelf again and make sure it is hard mounted vs. tape or glue.
Where else can I mount the radio?
Show a few pictures for me if you will please. I seem to be a visual learner.
Thanks,
John
Thanks,
John
Here is the way I mounted mine. The bracket is homemade and I used a longer bolt to mount it to the passenger side console using the existing bolt hole. Hope this helps.
http://project-jk.com/jeep-jk-write-...ation-write-up
http://project-jk.com/jeep-jk-write-...nd-model-1001z
Myrt,
Thank you very much. I keep forgetting about the Write Up section. I did get my antena mounted and tuned at the shop. I also ran the wire in from under the rear door, under edge of carpet, under trim inside bottom of door and now up behind the dash.
I will work on mounting it this weekend. I still need to find the power source. I will read the write up and see what I can learn.
Thanks all.
-John
Thanks all.
-John
Myrt,
Thanks all.
-John
Thanks all.
-John
Myrt,
I did use the write up page and installed mine. There was great information there.
I thought I posted a final shot in this thread, but guess I put it in the other.
Here is it.
Here is it.
