Mr. Answer Man
Old Nov 26, 2009 | 08:21 PM
w squared's Avatar
Originally Posted by AK4Dave
Good microphones, as well as punchy audio/modulation also come into play. I've heard signals that barely move the S meter, but their audio is so clean and crisp it punches through easily. I urge you to look into aftermarket microphones as some can be the difference in making a contact or not. Astatic makes a couple fantastic handheld mics.
As said before, there are just too many variables when the topic of "range" comes into play....
Or we could just steer them towards getting a HAM license.
Old Nov 26, 2009 | 11:33 PM
AK4Dave's Avatar
Actually I've been trying for quite awhile....... https://www.jk-forum.com/forums/jk-cb-ham-radios-128/heads-up-cbers-65693/
Old Nov 27, 2009 | 04:35 AM
Mark Doiron's Avatar
... I used to talk to a guy from a mountain top almost 50 miles away all the time with just the 4 watts. ...
Back in my ham days (WB6MPD for many years) I remember talking on two meters with ten watts from Chula Vista, CA to Lompoc when ducting would occur over the water. That's about 225 miles.
Old Nov 27, 2009 | 03:04 PM
AK4Dave's Avatar
Yes, we've done about the same bouncing our signal off Denali, or right here close off of Redoubt Volcano. Pretty cool. I really want to get a 2m SSB rig someday and try to bounce a signal off the moon down into the lower 48. I know a few that have.
I have also played a little with the satellites (2m UP/10m down) and that was a lot of fun as well, albeit a little tricky doing it all by hand....moving both my 2m yagi and 10m yagi to follow the bird across the horizon. Guys I know use computers and tracking devices to automatically follow the birds.
Old Nov 27, 2009 | 10:24 PM
w squared's Avatar
Apparently the Yaseu 8900 has a function built to factor in doppler shifts for satellite work...sounds like a lot of fun.
I think we've gotten a little off base here though. The OP was looking for info on what he could expect from a Cobra 75. With that CB, he won't be running an active mike, and I doubt that he can reasonably expect to talk to his trail buddies using skywave, sporadic E, or tropospheric ducting.
2 miles is perfectly reasonable with a good coax, a reasonable antenna, and the whole unit properly tuned. Under nasty conditions (terrain and atmoshpheric) you'll see as little as a 1/2 mile. Under favorable conditions (terrain and atmospheric) I would not be surprised by five miles.
Going beyond that is getting into territory that the average CB user isn't going to invest the time and effort into. If you do want to reach out further, then it doesn't make sense to chain yourself to running a 4 watt AM transmitter...and that spells "HAM license"
Old Nov 28, 2009 | 10:19 AM
AK4Dave's Avatar
Agreed.....But when the solar cycle really gets going they'll be lucky to talk across the street.....lol. Exaggerating I know, but 2 solar cycles ago I had a CB that was tweeked to about 12 watts AM, and it was connected to a full sized 5/8 wave vertical "Maco" antenna up at about 50 ft. When the dx started pouring in EVERY day, I was LUCKY to hear a guy in a mobile 3 miles away. And that was on flat unobstructed ground. These guys have NO idea what they're in for until it happens. Gonna be a lot of frustrated CB'ers out there.....like I was.
Old Nov 28, 2009 | 10:26 AM
AK4Dave's Avatar
Wow......I just checked it out.....what WILL they think of next...???!!!
http://www.yaesu.com/indexVS.cfm?cmd...5&isArchived=0
