Need cb antenna help
Old Jul 15, 2013 | 12:38 PM
MojaveJK's Avatar
Originally Posted by BlackRockBurner
Suggest Right Channel Radios. Good website with tons of info.
I went on there. I'm very interested on the fire ring thing, but just need more info
Old Jul 15, 2013 | 12:56 PM
BlackRockBurner's Avatar
Where and what type of mount comes into play with what type of connector for the coax. How you plan to route the coax should be considered too.
Old Jul 15, 2013 | 12:59 PM
MojaveJK's Avatar
Well I'm gonna run it straight where the stock 3d brake light goes I think, so if you could show me some good things I should consider to order would be great
Old Jul 15, 2013 | 01:43 PM
There are many mounts that go to the spare tire area although it's not the best place to mount an antenna. If you want to mount in that area, suggest Arizona Rocky Road antenna mount. It places the antenna base above the tub and spare tire reducing transmit waves feeding back to the radio. Use the screw in terminal (Firering not needed) and no matter what mount is used, ground with strap to the tub. The hinges do not conduct well so ground to the tub.
