Need help SWR 2.25/2.5
Old 07-10-2014, 05:49 PM
bvanfossen's Avatar
How did you make out? I'm fighting the same thing
Old 07-10-2014, 05:58 PM
NVW-SSV's Avatar
Waiting on replacement 18ft fire ring and then try again. Will advise
Old 07-14-2014, 03:53 AM
NVW-SSV's Avatar
Installed new 18 ft Firering and grounding wire from lower bolt on antenna mount to tire carrier bolt. (Dremel off the paint/powder coat &radic and now at 1.4/1.5. Thanks to Firestik for good service/free replacement under warranty
Old 07-16-2014, 08:00 AM
bvanfossen's Avatar
I also ground off the powder coating from mount and tire carrier. I also replaced the powder coated tire carrier bolts with stainless steel. I'm at 1.5 swr also. I've been thinking about running a ground strap from antenna mount to the jeep tub..
Old 07-16-2014, 08:03 AM
bvanfossen's Avatar
Where did you get your mount? I like it. Also, post a pic of your ground strap. Thanks
Old 07-16-2014, 02:24 PM
NVW-SSV's Avatar
Ordered directly from TF. Good deal when mentioning the forum.
Quick Reply: Need help SWR 2.25/2.5
