Need some help with multi antenna setup VHF, CB, Scanner
Hey all you HAM and Radio ninjas out there,
I need some help with a multi antenna setup.
I currently have a Relm VHF radio and Firestick antenna mounted along with my Cobra CB and separate firestick antenna.
I love how the firesticks work and function with both the CB and VHF Radio.
Does anyone know if i can use a different firestik ( or if they even make one) that i can use with my new BearCat 355c Scanner ?
http://www.uniden.com/content/ebiz/u...s/BC355Com.pdf
If i can use a firestick i will already have solved the mounting / grounding issue so im not to worried about that
I have never used a fire stick for VHF as I'd think you's have to chop a crap ton of wire out to make is short enough.
You might wanna look into a hamstick in the frequency ranges you want. antenna legnth is not AS important for listening as it is for transmitting.
