Practical implications of SWR
Old Apr 18, 2009 | 10:25 AM
AK4Dave's Avatar
Default Practical implications of SWR
The most common case for measuring and examining SWR is when installing and tuning transmitting antennas. When a transmitter is connected to an antenna by a feed line, the impedance of the antenna and feed line must match exactly for maximum energy transfer from the feed line to the antenna to be possible. The impedance of the antenna varies based on many factors including: the antenna's natural resonance at the frequency being transmitted, the antenna's height above the ground, and the size of the conductors used to construct the antenna.
When an antenna and feedline do not have matching impedances, some of the electrical energy cannot be transferred from the feedline to the antenna. Energy not transferred to the antenna is reflected back towards the transmitter. It is the interaction of these reflected waves with forward waves which causes standing wave patterns. Reflected power has two main implications in radio transmitters: Radio Frequency (RF) energy losses increase, and damage to the transmitter can occur.
Matching the impedance of the antenna to the impedance of the feed line is typically done using an antenna tuner. The tuner can be installed between the transmitter and the feed line, or between the feed line and the antenna. Both installation methods will allow the transmitter to operate at a low SWR, however if the tuner is installed at the transmitter, the feed line between the tuner and the antenna will still operate with a high SWR, causing additional RF energy to be lost through the feedline.
Many amateur radio operators believe any impedance mismatch is a serious matter. However, this is not the case. Assuming the mismatch is within the operating limits of the transmitter, the radio operator needs only be concerned with the power loss in the transmission line. Power loss will increase as the SWR increases, however the increases are often less than radio amateurs assume. For example, a dipole antenna tuned to operate at 3.75MHz—the center of the 80 meter amateur radio band—will exhibit an SWR of about 6:1 at the edges of the band. However, if the antenna is fed with 250 feet of RG-8A coax, the loss due to standing waves is only 2.2dB. Feed line loss typically increases with frequency, so VHF and above antennas must be matched closely to the feedline. The same 6:1 mismatch to 250 feet of RG-8A coax would incur 10.8dB of loss at 146MHz.
See also "SWR Meter"...... http://en.wikipedia.org/wiki/SWR_meter
Old Apr 18, 2009 | 11:39 AM
N2MWL's Avatar
good info Dave....
Old Apr 18, 2009 | 11:53 AM
RedDavid's Avatar
Sounds like it would be more important performance wise to have as low a SWR as possible when running low power ie CB at 4watts or a QRP rig?
Old Apr 18, 2009 | 12:03 PM
AK4Dave's Avatar
indeed............with ANY power output.
Old Apr 18, 2009 | 05:37 PM
Desert Fox's Avatar
Veteran: Navy
Smile
Good "poop" Dave. My thoughts exactly. Not all on this board agree.
KI6VBQ
