show ur different CB mounting spots
Old Apr 13, 2011 | 07:29 PM
  #111
miramontes's Avatar
Originally Posted by moabicon
WINNER!!!
imho
This is the one I purshased. I think I will also mount it like you.
Thanks for sharing
Old Apr 14, 2011 | 03:40 PM
  #112
exorcized's Avatar
This spot works perfect for a big ole Cobra.
Who uses the rear cup holders anyway?
Yes the lid opens all the way up.
Made this mount from a spare hunk of metal.
Old Apr 20, 2011 | 11:51 AM
  #113
csb93's Avatar
1.05 with of hardware at home depot and this is what you end up with!
Old Apr 20, 2011 | 11:55 AM
  #114
arasco85's Avatar
Originally Posted by jeepin08
I like a lot of people, like my stuff not to get stolen so...
here it is
And behind the curtain lol
When not in use I just reinstall the cover and it disappears! I plan on installing one of toad's cb mic holders when the basement builders come around again. But until then I hang the mic over by the gauges... up and out of the way. Also the cb can be tilted down to get a better view of the front of the cb. And for you big cb guys,... there is enough room in there to hide one of those as well.... atleast as far as I can tell
Bought a mic holder bracket from Toad here are some pics
install pics and description for anyone interested
I had used a piece of scrap stock steel that I had laying around about 1" wide to help stiffen up the metal bar that is already there. I drilled 3 holes in the steel stock but only one in the original metal bar. So the only place where the cb actually bolts to the jeep is the one hole; metal washers on the other bolts help fasten them to the jeep's metal bar. Pics should be able to show you what I mean. Let me know if you have any questions.
any questions let me know
thats a badass spot. should have checked this out before i did mine!! sorry for reposting the entire post
Old Apr 20, 2011 | 01:26 PM
  #115
jcopel's Avatar
You can only see it through the rear passenger side window and that is tinted. Its pretty well hidden.
ID:	152092   Click image for larger version
ID:	152093   Click image for larger version
Old Apr 24, 2011 | 08:31 AM
  #116
Frozenman's Avatar
Default overhead mount (from old aluminum piece laying around)
Old Apr 24, 2011 | 09:07 AM
  #117
rinkishJK's Avatar
Originally Posted by Frozenman
That looks sweet with the diamond plate piece. Thats the same radio (galaxy 929) in the same spot as me man!!! Nice job for sure!!
thunderbolt via tapatalk.
Old Apr 26, 2011 | 06:17 PM
  #118
8000ft's Avatar
Name:	2011 04 26_0006.jpg
ID:	154339Click image for larger version
Name:	2011 04 26_0008.jpg
ID:	154340Click image for larger version
Name:	2011 04 26_0010.jpg
Old May 3, 2011 | 09:31 AM
  #119
Chispas's Avatar
I am curious is the bracket comfortable or do you find it in the way? do you use it as a arm rest?
I think if I had a cushion on it I would rest my arm on it....
Old May 16, 2011 | 06:45 PM
  #120
tford911's Avatar
Originally Posted by Ko-hai
I actually use this mounting. The overhead console is amazing and it gives my Jeep just a little more of a rugged feeling from the inside.
I mounted my CB in the box, ran the cords through the Roll Cage Plastic Covers and down and through the gate in the rear. Looks really good as its totally seemless. Ran my wires through the Passenger A-Frame protectors.
what does it actually mount to? was it easy to install?
