Skinny on handhelds..........Please help
Old Sep 26, 2011 | 04:56 PM
Battlefrog's Avatar
The antenna that came with my unit has the adapter built in that connects to CB. In order to use the firestik and regular coaxial cable you need the adapter...
ht tp://m.radioshack.com/radioshack/product/detail.do?itemId=2293328&categoryId=&path=
Old Sep 26, 2011 | 05:08 PM
teamgreen666's Avatar
and does this unit run of the cig lighter also or just battery? I like both units. the midland 75-822 looks good see it for $82.00 on ebay.
Old Sep 26, 2011 | 05:23 PM
Battlefrog's Avatar
My cobra runs on AA or cig lighter...
Old Sep 28, 2011 | 07:27 AM
Got myself the midland 75-822 today on ebay $82.00 just need to find my self a firefly antenna next.
Old Sep 28, 2011 | 08:42 AM
Battlefrog's Avatar
I almost bought that.... Let us know how it works..
Old Oct 5, 2011 | 01:03 PM
nitzo's Avatar
I got one also and added the cobra external antenna.
Old Oct 12, 2011 | 01:23 PM
nitzo's Avatar
Update: I'm going to mount a permanent Fire stick as I'm not so sold on the magnetic antenna. If the top is up you have to route the cable thru a door opening(as the only metal to get to is the hood) and I'm really not digging that.
Advise?
Thanks
Old Oct 12, 2011 | 03:42 PM
Navyvetnorwich91's Avatar
Veteran: Navy
Originally Posted by icycle
I've got a Midland 75-822 and it's both a handheld (battery pack ad antenna) or you can put base on where battery goes that runs power from the cig outlet and hook it to a larger antenna. Works great for quick placement on the jeep. The only thing left when I take it out is the antenna cable. My dad has the same one on his BMW K1200 and says it's great for bikes. Has scanning on cb as well as weather radio
I have the same setup. I have an external antenna mounted on top of my spare tire carrier with wiring running inside the cabin to the front and it pops out of my carpet in the passenger foot area. I can then plug my Midland into it and plug the power cord into my dash plug. Works quite nicely for me since I only go out maybe once a month with my club.
Old Oct 12, 2011 | 06:02 PM
Sahara_Maverick's Avatar
Is it better to run the cable on the floor or on the roll bars? I've been thinking about doing the second but apparently most do the first. Any reason for that?
Old Oct 15, 2011 | 04:22 PM
Battlefrog's Avatar
Advise?
Thanks
Not true... I run mine through the rear side window and the antenna mounts right near gas cap. Or, I run it through the tailgate window and mount the antenna right to the tailgate... I've been in some thick woods with that little antenna and spoke with other jeepers 1 1/2 miles away with no problem... For a small antenna, it's got some range..
