Ssb
From: Simi Valley, Ca., Taylorsville, Ut. and places in between
Yes, it can be used strictly as a 40 channel cb.
Simply put, what a sideband cb radio does is you have 40 channels like a non sideband radio.
But you also have the capability of spliting each of the 40 channels.
They are fun once you get the hang of how to operate it.
Out in the desert SSB makes a lot of sense since the distances can be greater between vehicles. That extra power really does help you punch through.
The only problem I see is that the radios for SSB tend to be full sized, and since the fine engineers at Jeep didn't consider putting a CB (or power or coax) into the thing it makes it a lot harder to mount them. I had a Texas Ranger 966 mounted on the back side of my center console, but passengers kept kicking it. I finally gave up and put a Uniden 510XL on the center console beside the driver. I had it tuned up when I bought it and it really does get out pretty good.
Sure would like an SSB rig again though....
I
I
That's what I thought. I always wanted to try one. Just be using it to fool around with while I'm out in the Jeep camping or just sitting watching a nice sunset. This is one time where size is a problem. I was thinking the same thing about mounting it behind the console, but rear passangers would hit it.
Ok, so I'm seeing the whys and whatfors, but correct me if I'm wrong, (which I'm sure someone will do), you still have the "normal" 1-40 CB channels, correct? Then, you have "side channels" along each of the 40 CB channels. So the radio can be used strictly as a "CB", but you just have a "side" choice to communicate with someone on the "like" side channel?
SSB'ers are generally on 30 and above with Ch38 LSB as the calling channel.
On AM the channels are basically like this:
Ch4 Off roaders
Ch6 Skip shooters
Ch8 Spanish speakers
Ch9 Emergency
Ch12 Old timers
Ch15 Truckers
Ch17 Truckers Los Angeles and OC
Ch19 Truckers
Ch4 Off roaders
Ch6 Skip shooters
Ch9 Emergency
Ch12 Old timers
Ch15 Truckers
Ch19 Truckers
I'm studying for my HAM license now. I write the exam when I get back from my current overseas stay, and will be installing either a 2m/70cm or a 10m/6m/2m/70cm mobile rig into my Jeep when I get home
The areas that I normally wheel in actually have a lot of 2m repeaters on surrounding terrain points, so I anticipate fairly good coverage
