What to order
Old Sep 14, 2015 | 04:40 PM
WkFish's Avatar
Default What to order
Hey guys, I have a JCR shield carrier which I am planning on mounting my firestik to. I already have a cobra 75 WXST and now I need to find what coax cable, and what antenna I should order. I park in the garage so I was thinking of getting a quick disconnect for the antenna but should I pair this with a spring? Also 3 ft or 2 ft antenna, fire ring or normal coax? Links appreciated!!! Thank you guys!
Old Sep 14, 2015 | 06:12 PM
TURTLECON's Avatar
I have the same carrier, but I mounted mine to the bumper, since the antenna mount on the carrier is too high for day to day use. Get 4', with 18' coax & firering, and the quick disconnect will be a nice feature for some parking garages. You don't need a spring, but I think that's personal preference.
Old Sep 15, 2015 | 05:42 AM
WkFish's Avatar
Originally Posted by JK-FREAK
I have the same carrier, but I mounted mine to the bumper, since the antenna mount on the carrier is too high for day to day use. Get 4', with 18' coax & firering, and the quick disconnect will be a nice feature for some parking garages. You don't need a spring, but I think that's personal preference. <img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=624553"/>
thanks man what roto mount is that? Looks sweet!
Old Sep 16, 2015 | 05:46 AM
doberman1911's Avatar
I have my antenna mounted to the cowl so a spring is needed. However, since you are mounting on the tire carrier (btw,not the best location) a spring probably won't be that useful as the tire will interfere with any flex. You may want to consider a more flexible antenna such as the Wilson flex over a firestik. I would opt for the quick disconnect and two antennas of different lengths if you park in a garage daily. This is what I did as I got tired of disconnecting my 4ft firestik every night. I purchased a shorter 2 ft firestik for ever day use and us the 4ft for off-road and long highway trips.
Old Oct 2, 2015 | 06:15 AM
TURTLECON's Avatar
It's a custom mount
