What size antenna?
Old Dec 15, 2009 | 05:47 AM
Skippman's Avatar
I'm using a quick disconnect from CostalTech but you can get them pretty much anywhere they sell CB antennas.
Old Dec 21, 2009 | 03:36 PM
Vlado's Avatar
I use my CB in frecuencies that go from 144.000 upto 150.000
Could anybody tell me wich firestik would perform the best on an open road trip ?
Best regards
Old Dec 21, 2009 | 04:21 PM
piaa_nissan's Avatar
Best regards
That is a 2 Meter Ham rig which is illegal in the US and other countries to use unless you have a license and it is not called a "CB". All Firestik's are designed for 26.965-27.405 which is the designated frequencies for Citizens Band (CB) in the US and other places. Your going to need to look at other options such as a Diamond, Larsen or the like, that is if your licensed or don't mind operating illegally
Old Dec 27, 2009 | 05:06 PM
giolll's Avatar
I use a 4' firestick...work great
Old Dec 27, 2009 | 05:39 PM
For a two meter radio?
Old Dec 28, 2009 | 06:18 AM
mainejeeper's Avatar
For some reason, my SWR gets worse (higher) the higher my antenna is! When I screw my antenna to a firestic spring to help give it flex, it pushes my SWR to dangerous levels.
Old Dec 28, 2009 | 06:46 AM
w squared's Avatar
Have you tried tuning that antenna after putting the spring in place?
Any time that you change mountings or add a spring or QD unit, you should re-tune.
Old Dec 28, 2009 | 06:47 AM
This can happen and the only way to compensate is to remove the spring or cut the antenna which with most of the new firestiks is impossible because they use a tuning screw. Try unscrewing the tip and check your readings sometimes this will help. Otherwise you might have to look at a different antenna that can be cut down if you want to use the spring.
Old Dec 28, 2009 | 11:16 AM
yes, I tried to retune after adding the spring, but found it impossible. Even if I remove the tuning screw on top of my firestik antenna, the SWR is too high. Cutting the antenna would be the only solution. I guess I should have just bouht the 3' antenna since cutting a 4' is the only solution. I bought the 4' and a sprng knowing that the 4' would be a bit tall on the trail. I figured the spring would keep it safe. Waste of money
Thanks for the help and feed back guys.
Nathan
Old Jan 1, 2010 | 07:31 AM
Vlado's Avatar
Thatīs right !! My bad !! I use a VHF radio, not a CB ! In the US is illegal to use a VHF ? If not, what type of antenna would you recomend me, cause i use a 5db antenna, but itīs made of steel and i have cut up severall of them in off road trips. Is there any VHF antenna made of plastic or rubber as the firestick ??
Best regards
