12v ignition power source
Old Dec 24, 2008 | 07:26 AM
gillespk's Avatar
Default 12v ignition power source
I am installing a Parrott blue tooth and need some help. On the ISO harnesses for the 2007 Jeep, you have to run a seperate wire to a power source that is run by the ignition. I thought of simply tapping the power accessory on the left to make it easy. This small of a project seems to be overkill to run power from the battery. Two wires are on the accessory plus, black/white and green/orange (maybe blue was dark and in a hurry). Before I take it all apart and start installing, is it safe to assume the green/orange is my 12v + source? I can not find a wire schematic for the jk yet, anyone got one?
Any other suggestions for the power source? Also, where have people had luck installing the mic for bluetooths (either uconnect or parrot or whatever)
thanks
Old Dec 24, 2008 | 07:57 AM
rickc309's Avatar
I needed a keyed power source for my Warn solenoid power disconnect. I taped into the keyed power outlet on the left side of the center panel. The positive wire is the center wire on accessory outlet. It was about a 5 to 10 minute job from start to finish. Just remove the top dash panel and the dash center panel. You can do a search to find out how to remove the panels.
