2014 rubicon 2dr - esp abs kils switch fitting
Old Apr 29, 2014 | 11:00 AM
scotchyl's Avatar
Default 2014 rubicon 2dr - esp abs kils switch fitting
I have a new 2dr 2014 rubicon and do a lot of desert driving. People have mentioned that car can cut out if tilted above certain angle because car thinks it's going to roll over. The way round is to either remove J6 fuse or Crete a kill switch to disable this fuse when off roading in desert.
Has anyone else done this or know how this can be done. Want to avoid holes in the new interior.
Thanks.
Sent from my iPad using Tapatalk
Old Apr 29, 2014 | 03:22 PM
Mattk11's Avatar
Originally Posted by scotchyl
I have a new 2dr 2014 rubicon and do a lot of desert driving. People have mentioned that car can cut out if tilted above certain angle because car thinks it's going to roll over. The way round is to either remove J6 fuse or Crete a kill switch to disable this fuse when off roading in desert. Has anyone else done this or know how this can be done. Want to avoid holes in the new interior. Thanks. Sent from my iPad using Tapatalk
. Car?
Old Apr 29, 2014 | 06:57 PM
scotchyl's Avatar
Jeep rubicon
Old Apr 29, 2014 | 08:43 PM
suprablaski's Avatar
There is a write up for this around here somewhere do some searching
Edit: found it https://www.jk-forum.com/forums/jk-write-ups-39/esp-kill-switch-writeup-260247/
