2014 wrangler stereo question
I installed a NTG4 RHR unit in my wife's jeep. I found a factory subwoofer it put in the back. Question can I buy the factory amp and it will plug and play or do I need a harness?
Look under the dashboard on the driver side under the steering wheel. If you have a harness for the factory amp it will be there. If you have the factory sub you should have the wiring for the amp
