2015 missing amp and wiring problem!!
The good news ... became a 1st time JK owner a couple weeks ago. Used 2015 Rubicon unlimited. Thanks for letting me join the club!
The less good news... bought this from a dealer from the country who had purchased it from a friend/neighbor as a favor to sell. The prior owner did not seem to take much pride in ownership from my detailed inspections.
The bad news.... as I attempt to plan for a stereo upgrade (has the premium Alpine system with sub), I discover lots of plugs disconnected (power inverter, Uconnect system) for starters then discover the factory amp is missing altogether!!!! and then I find the wring harness to the amp has been butchered. Who knows why? However, I am missing an entire plug (see pic) and the other has several wires cut (see other pic).
Question - I can probably splice the cut wires on the one plug but the completely missing one... any ideas how find the right match? I guess I could get an entire new wiring harness for $$$$ but maybe I should just get an aftermarket amp setup? I want to use the Alpine sub I have but I think its fairly proprietary (1.3 ohm) so Im not sure a mono amp would work, even if I could sort out the wires. Thoughts? Help? Bueller
Missing connector (saw this from a youtube install to a factory amp.)
Hack job
hack job, different view
Hack job
