2330NEX Control issue
Just installed the 2330NEX in my 2017 Wrangler. I used the Maestro RR and CH1 harness to retain the steering wheel controls. Everything works fine, and the steering wheel controls work as they should. However if I press and hard button on the 2330NEX the steering wheel controls will stop working until the unit is powered off, then back on.
I've reflashed the RR and checked all the connections. The Steering wheel controls work fine as long as I don't press any hard buttons on the 2330NEX
Has anyone had a similar issue? And advice? Thanks.
