430N Replacement?
Hi guys. Navigation is hanging up in the startup screen and it sounds like there's no solution for this other than replacing it. Problem is I really like the integration of the stock unit. Getting the turn by turn on dash by the speedo - etc.
Is there an aftermarket unit that will tie into this? I know I can get the steering wheel buttons to work - but what about the Bluetooth mic, and dash features? |
In order not to start another similar thread I will jump into yours - hope that you don't mind.
I was looking at upgrading my radio with anothet stock unit that had mote functionality but with their costs beijg in the 300-400 range I am starting to look at the android units... I wonder what all everyone has and why do they like it or dislike it... |
Originally Posted by sea bass
(Post 4305377)
Is there an aftermarket unit that will tie into this? I know I can get the steering wheel buttons to work - but what about the Bluetooth mic, and dash features? I'm in the same boat as you. Based on the research I've done, it appears it's a hard drive issue, and only way to fix is to replace the radio. Mine is under warranty, so it will be replaced sometime soon. Good luck on finding a replacement radio. |
I just replaced my head unit with a Pioneer and a Maestro interface. It uses the GPS on either Android or IOS. It works great. But with that said, I just put a similar Kenwood in my wife’s car and like the interface better. I’ll probably be removing my Pioneer soon and replacing it with a Kenwood just because it is a bit more intuitive to use.
That's good to know - thanks for he feedback
