50" Lightbar install
Old Jan 13, 2014 | 07:07 PM
NateSamJK13's Avatar
Default 50" Lightbar install
So, let me first start off by saying I have the greatest girlfriend ever!!! For Christmas I got the following:
- poison spyder 50" lightbar mounts (aluminum)
- 50" lightbar
- rigid dually pillar lights w/ poison spyder mounts
- poison spyder Hawse fairlead (black)
- recon 10,500 lbs winch w/ synthetic rope
- recon smoked turn signals
- upol raptor liner kit
- factor 55 loaded thimble (silver)
+ (yes, I said plus!!!!)
- (2) craftsman 6 drawer tool chests
- 334 PC craftsman tool set
Am I blessed or what?!!
Now for my question.....I had my poison spyder lightbar mounts Line-x'd and want to install them and the lightbar this weekend. My cousin is going to help me since I know jack about electrical. (I live in St. Louis area and it's one of the worst cities for crime. Don't want all my gifts to disappear!). Was wanting to know if anyone has installed a lightbar with a quick disconnect near the top of lightbar so I can remove it and put in Jeep whenever I need? Or any ideas for security or to make it less likely to get snatched? I try to stay away from areas where this might happen, but also want it for anytime I'm looking to remove it.
Any detailed write ups, ideas, suggestions would be greatly appreciated!
Old Jan 13, 2014 | 07:20 PM
Km7799's Avatar
Not able to help with your question, but does your girlfriend have a sister?
Old Jan 13, 2014 | 07:21 PM
[/attach][attach=config]523503[/attach][attach=config]523503[/attach][attach=config]523504[/attach][attach=config]523505[/attach][attach=config]523506[/attach][attach=config]523507[/attach]
ID:	523503   Click image for larger version
ID:	523504   Click image for larger version
ID:	523505   Click image for larger version
ID:	523506   Click image for larger version
Old Jan 13, 2014 | 07:25 PM
Here's more pics
ID:	523510   Click image for larger version
ID:	523511   Click image for larger version
ID:	523512   Click image for larger version
ID:	523513   Click image for larger version
Old Jan 13, 2014 | 07:26 PM
And the last few
ID:	523515   Click image for larger version
ID:	523516   Click image for larger version
Old Jan 13, 2014 | 07:27 PM
She does....but I got the best! The sis is Alittle nutz
Old Jan 13, 2014 | 07:39 PM
TURTLECON's Avatar
I believe rigid (or someone) came out with a locking mount that replaces the mounting bolt on the sides of the lightbar.
What's the difference between the factor 55+ and a "regular" factor55? I'm in the market for one.
Thanks!
-Mike
Old Jan 13, 2014 | 07:45 PM
i think the loaded just has the rubber bottom included so you do not have to buy separately.
Old Jan 14, 2014 | 04:28 AM
Sparks1013's Avatar
I'm don't know about jk-freak's suggestion but you could always use security bolts. It would be like a wheel lock for your lightbar. Google it for ideas.
Old Jan 14, 2014 | 06:46 AM
nik81818's Avatar
The loaded has a titanium pin where the normal factor 55 has a steel pin. The 55plus I believe is bigger and accepts a bigger shackle. Not 100% on this tho
