77kick10's installed
So I installed my kickers today. The drivers side was the biggest pain in the ass, I wound up not being able to get the speaker box out so I had to bend a screwdriver with a torch and vise in order to unscrew the speaker. Then putting the dash back together, I wound up cracking one of the side window defroster vents on the cluster bezel (snapped clean in the middle so I matched the two pieces up and you can barely notice anything happened, but I know
). Everything else went super easy though, and the sound quality is well worth it.
First off, thanks for buying KICKER!
I am curious, were there any issues with the installation manual as you went through the installation process? Do you think of any changes or elaborations are needed that would have helped you with the drivers side issue you had?
Thanks!
Todd
Thanks!
Todd
Thanks!
Todd
Thanks!
Todd
