abs bas light when flexing
Old Jul 7, 2012 | 06:03 PM
cis911's Avatar
Default abs bas light when flexing
so i went to the beach today, drove around and i found this tree stump that was above ground at an angle to where i could drive on it and flex. well as soon as i reached the end of the stump my abs and bas lights lit up. now i was already in 4lo so the dash said esp off and the esp indicator was lit as normal. i wasnt fully flexed none of my lines abs and brake had a lot of slack. i drove off the stump, turned the jeep off for a few seconds, turned it back on and it was still lit. i started driving away and after 200 meters it turned off. im wondering if this has happened to anyone else or if this is normal.
Old Jul 7, 2012 | 07:26 PM
cis911's Avatar
It's happened once before but didn't think much of it
Old Jul 8, 2012 | 04:00 AM
cis911's Avatar
im guessing its only happened to me lol
Old Jul 8, 2012 | 04:39 PM
cis911's Avatar
Anyone? I'm about to let it be
Old Jul 8, 2012 | 04:53 PM
maine07jk's Avatar
It didn't happen that way with me, but I am guessing that you are stretching the wire and finding a weak spot in the wire when flexed.
Old Jul 8, 2012 | 05:10 PM
cis911's Avatar
I'm going to see if the light goes on when I drive up with the driver tire.
Old Jul 8, 2012 | 05:24 PM
Mark73's Avatar
Mines on an off all the time . Not sure why though ? Mine started after my lift . I just thought it was because it was higher messing up the system. Our jeeps know how far they r leaning over and such . Not sure but wish I could just shut all off
Old Jul 8, 2012 | 05:46 PM
maine07jk's Avatar
When I just replaced my hub and sensor, I took a look at the wires of the sensor. They are not very beefy at all!
Old Jul 17, 2012 | 04:25 AM
cis911's Avatar
Yeah I went to uwharrie this weekend and it did the same thing it would turn on while flexing and off on flat ground
Old Jul 19, 2012 | 08:02 AM
nwbronco's Avatar
Mine is on full time, along with the BAS/ESP lights. Checked all the wiring and sensors. They are all tied together. I am thinking it may be the ABS module.
Bob K.
