Accessory Outlet quit working
A couple of months ago one of my outlets quit working. I checked the fuse and it was fine. I'm guessing that a wire got burned somewhere. Today I got out there to run a new power line to it and found something interesting. Somebody can correct me if I'm wrong... These are fused at 20 amps, which should mean a 14ga wire, but it had 18 ga wire. Is this right?
I ran a new line, with a 14ga wire and a 20 amp fuse.
When I wired in the selectable switched/hot outlet from fuse M7, I used 12 gauge wire.
https://www.jk-forum.com/forums/jk-e...5/#post4034020
