Add-a circuit question
Old Oct 2, 2012 | 07:01 PM
nmoldie's Avatar
Default Add-a circuit question
New to the forum,lighting and Jeeps.I should get my Hella 500FF driving lights delivered tomorrow. I plan on using a power source from the fuse box for the on/off switch.I got a 10 amp add-a circuit today. Let me see if I can get my thoughts on paper...In my fuse box ('13JK) fuse slots M-9 and M-14 are empty.They are both hot with the key on.Both slots call for a 20 amp fuse. My thinking is...Since the slots are empty I do not have to add a 20 amp fuse to the add-a circuit??!! Just a 10 amp fuse in the top slot of the add-a-circuit and I will be good to go????? If my thinking(?) is wrong which fuse could I piggyback onto and be OK? Thanks
Old Oct 3, 2012 | 04:44 PM
nmoldie's Avatar
HELP!! Gonna start in the morning!!
Old Oct 3, 2012 | 04:54 PM
ronjenx's Avatar
You will be fine with the 10 amp fuse, assuming the power to your switch will be used to throw the relay for the lights.
Old Oct 4, 2012 | 07:21 AM
nmoldie's Avatar
Yes I will be using a relay. Thank you.
