Add sub to infinity system
Old Mar 14, 2011 | 09:09 PM
roxbury29's Avatar
Default Add sub to infinity system
Hello, curious which would be best. First stereo upgrade I want to do, is add an additional sub to my infinity system. Either LOC at the Subwoofer then to amp, or use a PAC harness at the radio before the infinity amp. Does anyone know which way will work better. I always thought to go from the radio would be better, but tapping from the sub would already give me just the lows.
any thoughts!!!!
LOC is a little cheaper - about $ 20 to $ 40
PAC Harness seems to be about $ 80 / but no splicing needed
Old Mar 15, 2011 | 05:30 AM
REDLINE217's Avatar
What kind of sub are you wanting to add ? And why would u want to add on to the factory system ? You would be way more pleased just taking the factory sub out and putting one nice sub in there
Old Mar 15, 2011 | 01:02 PM
roxbury29's Avatar
I know, however Jeep decided to mold the sub in the new 2011 interiors, you cannot just take the sub out. I wish I had not ordered my 2011 with the infinity system, because even if I add a sub, I cannot take out the infinity one. I will send you a pic if you havent seen the new ones
Old Mar 15, 2011 | 01:05 PM
Matt08jk's Avatar
You may be able to remove the molded sub enclosure and replace with the non-infinity version of the plastic panel. Worth some thought.
Old Mar 15, 2011 | 03:54 PM
roxbury29's Avatar
Hi, i thought about that too to save some room, but the cost I doubt will be worth it.
