Added Fus/Relay Panel-Lots of Pics
In the pictures you can see the mounts. When you order the fuse block you can get them. They come with two holes to mount the block and one large hole on the very bottom to mount the whole assembly.
Vernnz,
If I wanted to do something like this (installing the Busman) for future expandablitiy (like when i can finally afford the off road lights and winch, etc) at the same time I'm installing my CB radio, and wired the power to the Busman instead of directly (with a fuse) to the battery, would there be any extra interference or noise created? This would be, say, versus connecting power directly to the battery, which many folks have recommended to me.
I'm just thinking ahead, so I don't have to clean up the wire mess later.
Thanks!
Thanks!
No extra interference. A CB transmits 4W. I am going to connect a HAM radio rated at 100W to a Bussmann fuse/relay block. Eventually. Mounting the Bussmann right next to the battery will be the same as wiring direct to the battery.
Remove the windshield wipers and 4 torx screws thenremove the 4 plastic "rivets" (for lack of a better word) in the center around the vent
It came with the bracket but I used some steel tubing cut to length (from lowes) to raise it up even higher. Then I just used some looong lag screws to go threw the bracket, steel tube and plastic underneath...
The switch for the compressor is in the back on the sub. I put it so that it was between the sub and tailgate when the gate is closed so cargo could not shift and accidently turn it on...
On position #4, which you said was ignition switched, where is the hot wire for that relay (or fuse, whatever it is. Can't tell from pics) wired? Is it wired to the ignition harness wire? Is that the only posiiton which is set up for that from the manufacturer, or can you hard wire or ignition wire the relays as you wish when you install it?
Nice job!!
Thanks
Nice job!!
Thanks
Nice job!!
Thanks
Nice job!!
Thanks
