adding accessories
There's a hole through the firewall on both sides behind the upper dash vents near the doors. Just pop off the side panel and you'll see it (you'll need to poke a hole in the foam with a screwdriver or wire hanger).
Here's a write up on how to run wires for lights:
https://www.jk-forum.com/forums/show...light-solution
