Adding Factory Fog Lights ......HELP
i have a 2007 X... no fog lights
im adding a ARB bumper...i purchased the "MOPAR FOG LIGHT KIT"
QUESTION...
i remove the connector "D"
instruction tell me to....... Insert WT/OR to cavity 11
......... Insert WT/YL to cavity 16
my connector already has a WT/OR in cavity 11
WT/YL in cavity 16
any ideas?...are these wires spares?. ...or not used...i wanted to avoid tracing the arounds the front
Thanks
trent
QUESTION...
WT/YL in cavity 16
Thanks
trent
Sounds odd. Most people without factory lights say they do not have the factory wireing. Double check that you are looking at the correct plug. Also double check that you are counting the pin-outs correctly. If all that works out and you are still correct. I would say to remove the wires that are in your way being careful to preserve them as much as possible. Insert your new wires and try to get to a point where you can check everything out. Stick with the harness that came with the kit. Other people that have tried to find existing harness have not worked out so well.
think i figured it out...
there is existing wire at connector D...it runs to another connector (under the power steering reservoir) this is where the wire ends...theres no wire on the other side of the plug...
must be a factory standard harness tho that plug under the powersteering reservoir,,
i will de-pin the connector and install the new wires with the new connector,.,,,
trent
trent
