Adding Pictures to 430N Media Centre (Problem-Help) 2012 Edition
Good day all.
I've tried to load pictures though the front USB interface on my 430N. Pictures are on the USB stick i am using, they transfer to the media centre fine, I can even make one of them the default screen picture. It's not the transfer that's the problem....
The next time I fire up the JEEP the pictures that I had recently added are no longer there. Only the defaule picture of the cliff/ocean is there.
Where the hell are these pictures going to????
N.B. The files that I am transferring are JPEG files....Shouldn't make a difference though..
Thanks in advance for your help.
I can't even get that far. I put my USB stick in and it says no files are on it. So I go and check and guess what all my pics are still on the stick. The pics are all JPEG
Happened to me too.
I just now did a google search and found this on another forum:
Thanks to you ALL! I got pictures to load to my 430N HDD!
Like jltcasper3, I thought I had tried all combinations... apparently not.
Pictures loaded:
1. From a flash drive
2. With an MP3 file in the root directory (it starts playing when you plug in the drive)
3. All in JPG format, some in root directory, some in a folder ... I did try resizing some but didn't do a very good job .. may retry
3. Press MY FILES, MY PICTURES, ADD and they all started popping up on the screen.
Pictures loaded:
