additional reverse light...is this possible?
Old Jan 3, 2012 | 02:00 PM
tomharley's Avatar
The third light is connected to the positive wire factory reverse light circuit and even grounded. When reverse gear is selected, all three lights.
Extra switch is powered from the light´s circuit and is connected directly to the circuit of reverse lights. When I turn on it, all three lights lit.
For me it works only when the parking or headlights lit. But it can be connected to the brake light switch circuit
Old Jan 3, 2012 | 02:03 PM
tomharley's Avatar
I did edit
"brake light switch circuit" not "brake light circuit"
Old Jan 3, 2012 | 02:06 PM
texwillys's Avatar
Originally Posted by NeverStock
you mind letting me know exactly where you tapped into the brake light circuit, and the wire color if you can remember? I did add the relay,no switch, and if I can get power somewhere closer than the physical battery, this mod will be done!
Thanks again!
I'll be glad to check for you, but I'm afraid not every JK is the same. It would be better for you to check with a test light or meter.
I'll get back tomorrow......
Old Jan 3, 2012 | 05:04 PM
JK-Ford's Avatar
For me it works only when the parking or headlights lit. But it can be connected to the brake light circuit
Reckless. Backfeeding a circuit like that is very bad.
Old Jan 3, 2012 | 05:29 PM
ShakyJake's Avatar
As is overloading factory wiring. Powering a 55W directly from stock reverse light wire is not wise. Use the stock wire to trigger a relay that draws power from battery is better, or use a few watt LED directly, not a 55W halogen off the tiny stock reverse circuit! It will surely work, but for how long and for how much potential damage down the road? A pair of these is adding 9 amps draw to the circuit. Reckless is right.
Old Jan 3, 2012 | 09:06 PM
JK-Ford's Avatar
X2 ShakyJake. Gotta have some pretty big kahonas to risk a Jeep for a $20 set of lights.
Old Jan 4, 2012 | 01:30 AM
tomharley's Avatar
OK ,I understand what you mean but it's proven nearly three years of operation.
Old Jan 4, 2012 | 04:44 AM
Rednroll's Avatar
Consider this.....The Mopar and other aftermarket trailer wire harness add-on kits for the JK tap directly into the rear tail lights. Thus, using the existing wiring that runs from the front of the vehicle to the rear tail lights. These trailer kit harnesses are designed to power additional lights on a trailer. So "if" tapping into the rear tail lights was such a high risk of causing fire like some are trying to lead you to believe....do you think Mopar would be selling a JK trailer wire harness that does exactly that?
Besides that, all the rear lights have a fuse that will blow before the wiring running to them ever reaches a point where the wiring could catch on fire, thus the fuse is there to prevent such a thing. So if the fuse blows, then that answers your question.....that you then need to run a separate wire from the front and use a relay. No need to over think this, or act like the sky is gonna fall if you tap into the existing wiring.
So tap away.
http://www.quadratec.com/products/92015_110.htm
Old Jan 4, 2012 | 05:11 AM
efan450's Avatar
So tap away.
Well said...I'm no electrical guy by any means but in my experience, I have a mopar trailer harness 7 pin and it hooks to the drivers side trail light harness...my small ATV trailer has 2- 5 watt side markers, 2- 35 watt tail lights, and 2- 35 watt turn signals...never given me a problem
Old Jan 4, 2012 | 05:13 AM
tomharley's Avatar
a good example, but the JK-Ford thinks about a problem with a circuit backfeeding.
