Aftermarket stereo install
Start by doing a search.
If you are in a 2007-2010 do the following:
Remove top center panel (pops out with prying)
Remove bottom cargo panel (with bungee net, also prys off)
Remove top 2 bolts for center dash
Remove bottom 2 bolts for center dash
Pry out center dash
All bolts are 7MM
Pry out center dash
All bolts are 7MM
Originally Posted by Cobra65
Gy's
I left out its a 2012 Wrangler--Didn,t realize that the dashboards were changed.
Thanks,
Vince
Thanks,
Vince
1. Remove the panel directly below the steering column, its snaps open from the top and pivots at the bottom, so pull from the top.
2. Remove 2 (7mm) screws holding the lower portion of the interment bezel (one on each side of steering wheel).
3. Remove the rubber tray on top of dash by just pulled upward and then remove the 7mm screw found under there.
4. Remove both center A/C vents, just turn them counter-clockwise till the click and then pull.
5. Putting your fingers through the A/C vent holes, you can now push the Window switch panel out from the inside and disconnect the wire harness.
6. There is one last 7mm screw inside below the window switch panel.
7. Now start gently pulling on the dash panel, starting near the left A/C vent area and working your way over to the top tray area and then down. It will pop up pretty easily. Just take care in the area around center A/C vents because the plastic is really thin around the snap clips and can break easily. (also, if you will put the steering wheel as low as you can get it, that will help give you some room when you start to pull it apart).
8. You're done.
Or just go to this thread, it has good pictures showing the locations and such. Click Here!
8. You're done.
