Aftermarket Sub Wiring
I installed an aftermarket sub and amp and have a question about the wiring. Those of you who have the OEM Infinity system and have installed an amp, which wires did you tap into at the Infinity amp for your signal? I am using a line converter before the amp.
Check numbers two and three in this post. hope it helps.
https://www.jk-forum.com/forums/jk-electrical-lighting-sound-systems-13/aftermarket-amp-put-place-based-off-everyones-threads-50299/
