Alarm Wiring
After a break-in, I decided that I need an alarm. I don't need anything crazy since I have a manual everything, so I picked up a Crimestopper SP-101 on Amazon for $33 (Can't beat that). The instructions are straight forward enough, but I'm looking to see if anyone that's done an alarm install knows the wiring for the JK. I know that all of them can be a little different, but any info would save me a lot of time with tracking down wires.
All that I am wiring is: Parking lights Dome light (for sensing door or tailgate being opened) Horn switch(under the steering column) Hood switch Ignition sense. There are a lot more options that can be installed, but this is all I need for my base model. I might put in a proximity sensor later. Any info would be a huge help, and time saver, for when I do this install this weekend. TIA -Kevin |
I'll pull the wiring guide tomorrow morning when I'm at work. 2007, correct?
Nevermind, can log-in at home using my work info. Parking Lights: WHITE/ORANGE(+) (Left) and WHITE/PURPLE(+) (Right) : Located in Passenger Kick Panel. Dome Light: YELLOW/WHITE (+) : Located in Passenger Kick Panel. Door Trigger: PURPLE (-) : Located in Driver Kick Panel. Horn Switch: DARK GREEN/PURPLE (-) : Located at Horn Switch Hood Switch: Run a hood pin. Ignition Sense:? Do you mean Key Sense? You should only need this if you are doing a remote start. Also, what are some of the other options? This is what I do every day, and can give you some pointers/advice. |
Thanks! That'll be a huge help. I think the ignition sense is just supposed to be a "hot while on" wire to turn off the alarm.
There are options for windows, power locks, trunk release, and add-ons for proximity and glass break sensors. But I don't need any of these. I might add a proximity sensor later. Thanks again! |
Question for the expert?
Originally Posted by Aideon
(Post 3418842)
Thanks. |
(Post 3418842)
Nevermind, can log-in at home using my work info. Parking Lights: WHITE/ORANGE(+) (Left) and WHITE/PURPLE(+) (Right) : Located in Passenger Kick Panel. Dome Light: YELLOW/WHITE (+) : Located in Passenger Kick Panel. Door Trigger: PURPLE (-) : Located in Driver Kick Panel. Horn Switch: DARK GREEN/PURPLE (-) : Located at Horn Switch Hood Switch: Run a hood pin. Ignition Sense:? Do you mean Key Sense? You should only need this if you are doing a remote start. Also, what are some of the other options? This is what I do every day, and can give you some pointers/advice. i've been wondering about the easist way to install a simple kill switch? dont know any alarm/stereo guys that can help me? |
Originally Posted by rtguy1
(Post 3419032)
Originally Posted by 4x4Play
(Post 3418986)
There are options for windows, power locks, trunk release, and add-ons for proximity and glass break sensors. But I don't need any of these. I might add a proximity sensor later. Thanks again! As far as wiring at the horn switch, I tapped mine under the column, and have had no issues with it. |
(Post 3419385)
Ignition: Pink/White (+) : ignition switch, black 5 pin plug, pin 3
(Post 3418842)
