Alpine PDX-V9 in dash of '11 2-door
Anyone have the PDX-V9 in the dash, under the steering column? It looks like it will fit, but how did you mount it?
Any problems with the amp causing interference with other electronics?
Thanks,
Brent
Thanks,
Brent
You don't have to worry about the amp interfering with other electronics.
I took out the speaker pod and the left bracket and was able to fit the amplifier into the position. Just need to figure out a way to support the amplifier. probably mount to a sheet of aluminum and use some wire to support the back end. I think i'll have all my wires connected on the right side.
Maybe I should have bought a smaller amp.
Thanks for the pic.
Thanks for the pic.
I took out the speaker pod and the left bracket and was able to fit the amplifier into the position. Just need to figure out a way to support the amplifier. probably mount to a sheet of aluminum and use some wire to support the back end. I think i'll have all my wires connected on the right side. Maybe I should have bought a smaller amp. Thanks for the pic.
