Amazon LED Offroad Lights
I bought a 32" LED light bar on Amazon in October and it came with the complete wiring kit for less than $100. I've used it a bunch and it really lights up the world. It has held up fine so far. Mounted above the windshield it made a harmonic noise that I fixed by wedging short pieces of 1/4" drip tubing between the fins in the middle of the back.
I have bought 3 light bars and the 4" lights that you did from amazon. The 50" straight combo bar I mounted on my jeep and is as good as the rigid light. It is made by USA light optics and sells for $246.00 Which is way cheaper than rigid. Similar light bar on rigid's site is $1700.00. I also bought a no name 32" that I wouldn't put up against small flashlight. The good ones use Cree led's from my experience.
This is one of the many brands that offer this style. i'm sure they're made by the same people.
Nilight 2x 4" 18w 6 Cree LED SUV Off-road Boat Headlight Spot Driving Fog Light + Mounting Bracket
Amazon.com: Nilight 2x 4" 18w 6 Cree LED SUV Off-road Boat Headlight Spot Driving Fog Light + Mounting Bracket: Automotive
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=589111"/> Got a light bar off amazon for around a $50 gamble awhile back. Turned out great, bright, strong, and held up to my pressure washer. Sorry don't remember the vender, I'll try to check old emails for you
Also, I'm going to be pm'ing you in the near future about your in dash cb install.
I have had bad luck with cheap 50" led light bars. But you get what you expect for the money. However even that has been ok. I'll have to pull it off at some point and seal it up better as it does get some moisture in it. But I just don't have $1500 bucks to throw at a Rigid led light bar.
