Amp remote cable to fuse box????
Over the past couple of weeks I have been looking for another power source to tap into for an audio amplifier remote cable. I have read numerous posts about tapping into the driver's side ciggy lighter. That is great info, but I already plug my radar/laser detector in there and I plan on tapping those wires as a power source for my LCD monitor.
Throughout all of my searching, I have not read one post where someone has tapped into the fuse block for power, only posts about adding an aux fuse block. I then began searching about the fuse box information and stumbled upon this picture.
I circled the fuses that pertain to the infinity amplifier and radio receiver. (I don't get why the M10 fuse is a 15 amp in the pic though).
I was thinking about running a wire to underneath the fuse for the radio to power the remote wire going to the amplifier in the trunk.
Or, what about the other open fuse locations I circled and put question marks by. Are any of those switchable sources that I can add a fuse to?
I'll need some advice from electrical gurus.
Clarify your question for me... are you looking for somewhere to tie in the power cable to the amp (usually a very thick red wire) or the remote turn-on lead (usually a blue wire)?
If it is the blue wire you are talking about, and you have an aftermarket head-unit, there there is a blue wire on the harness to tie into.
sounds like you just need the power for the remote turn on for the amp ? if so any 12 volt source that comes on with the key will work . i would just tap into the cig lighter that will work fine. even if you have other things on it . the amp is looking for a 12 v to turn on .
Yes. The remote cable to turn on the amplifier. But instead of cutting into the factory wiring I was going to put the wire underneath the fuse for the radio or Infinity amplifier. Either that or some other fuse that turns on when the vehicle is running.
https://www.jk-forum.com/forums/jk-cb-ham-radios-128/found-another-switchable-source-power-35210/
A good source, also sounds like you might reconsider running the added fuse block behind the glove box. It would serve you well..
Best wishes.
Best wishes.
Check out this thread. Seems like what you are looking for.
https://www.jk-forum.com/forums/showthread.php?t=35210
